Context: I'm designing a linkage mechanism as part of a university robotics design project. From previous analysis, I have determined the forces and torques applied to each member at all points in time throughout its cycle of operation.
For instance, here's the Magnitude of the forces acting on one member throughout a 60-second cycle (note: I'm not including the equations that describe these forces because they're very very long, and hopefully irrelevant to my question):
Magnitude of Forces acting on an example member, at each point in time.
Problem Since I know the forces at each pivot connection, I can resolve them (and the weight) parallel and perpendicular to each beam they act on. Designing for the total compressive/tensile force is therefore relatively simple.
Now I want to be able to design the members such that they can withstand the bending forces experienced during operation.
Current Attempt: I have resolved each force parallel and perpendicular to the beams it acts on, and was hoping to input the perpendicular forces into a shear force and bending moment analysis along the length of each member, as if it were a normal beam. However, as the linkage members are experiencing constant rotational and translational acceleration, they clearly aren't in static equilibrium like a typical structural beam! As such, when I plot the forces from one end to another, I end up with a big unbalanced discontinuity right at the end (rather than returning to zero as you'd usually expect):
Shear Force (Red) and Bending Moment (Blue) for an example member (same one as the force diagram above, where x is the length from A to C) in the linkage mechanism, animated through its operation cycle.
If I understand correctly, this implies that the internal forces due to applied forces at one end of the linkage don't propagate at all back down its length, which can't be accurate. So clearly I'm missing something...
Question: Is there any merit in this approach at all, or does the Shear Force and Bending Moment analysis I learned in 1st Year Structures fail as soon as something isn't in equilibrium? I expect this is the case, so what would the correct method be?
To be clear, I'm not asking anyone to do this analysis for me! I've just so far been unable to find any useful information on this aspect of linkage design, which really surprises me, so I can only assume that I'm missing something like the correct search term...
Thanks in advance for your help/advice!
