I want to calculate the von mises stress in a given structural member. I want to generate a von-mises plot from this data. The forces are according to the local coordinate system of the beam. Also, I am using linear simplification for the beam.
I have an FEA output file that has provided the following:
Node 1 Location: -5.200901, -4.278615, 4.095733
Fx(axial force), Fy(shear force), Fz(shear force), Mx (Axial torsion), My (shear moment), Mz (shear moment)
Node 2 Location: -6.272305, 2.599551, 2.654122
Cross sectional area of beam (A): 0.001764 The beam has a square cross section of width and depth of 0.015 and a thickness of 0.003
Length of beam (L): 7.10882
Given structural properties of the isotropic metal
Also, is it possible to interpolate the values in between and figure out the plotting in between?
Thanks in advance
