I have a beam as shown below that have a span having 60 cm in thickness and the other spans 30 cm do I consider this beam as continuous or does the changing in thickness affect that ? if there is anything like an article about these criteria (especially in ACI code)
1 Answer
Yes it is still continuous; all beams are still capable of producing a hogging moment above the columns.
$\begingroup$ Is there any limit from which I can't consider the beam in span 3 as continuous and analysis it as a simply supported ? $\endgroup$– J.DaouMay 8, 2017 at 9:50
$\begingroup$ No. It is nothing to do with relative thickness and all to do with how the connection is detailed. If both beams are connected together/to the column with full moment connections then the beam is continuous. $\endgroup$– AndyTMay 8, 2017 at 9:54
