How to design a drop panel at a column in case the column above is rotated or not aligned to the below column (see image below), the code that i am using is the ACI Code if any reference for the design of such a case is available.
In another cases we usually use the drop panel to reduce the span between two columns and reduce the effects of shear on slab (especially punching shear), in case of seismic/wind resisting building is there any loads or changes to the design of these special elements and how do they affect the behavior of the building ?
Thank you in Advance.
