Diagram
Torque due to force of gravity:
-Payload: 0.2kg x 0.3m x 9.81 = 0.5886
-Hand: 0.1kg x 0.25m x 9.81 = 0.24525
-Forearm: 0.3kg x 0.1m x 9.81 = 0.2943
Torque due to force of gravity = 1.13Nm
What about torque due to angular acceleration?
I know it is Torque = Moment of inertia x angular acceleration, However, the motor will be rotating the hand and the forearm around the x-axis.
So, how would I calculate the torque for this motion?
I assume you are trying to measure the torque needed to turn the arm horizontally to right or left.
If that's the case we calculate the angular moment, I as:
$$ I= \Sigma m_i r^2_i \ = \\ 0.2kg*0.3^2m+0.1kg*0.25^2m+0.3kg*0.1^2m \\=0.18+0.00625+0.003=0.027Nm^2$$
Not that we don't have g factor, and torque is:
$$T=\alpha*I$$
15
  • $\begingroup$ thank you for your reply!! So do I ignore the torque due to the force of gravity? So I'm talking about this movement: makeagif.com/gif/pronation-and-supination-of-the-forearm-pKemMR $\endgroup$
    – user36991
    Feb 17, 2022 at 18:30
  • $\begingroup$ no, if you needto lift you need the torque in X direction, if you need to turn you use the torque in z or y directio. if you dneed both you are dealing with 90 degre right hand moment and gyro precession. and it bocomes substantially more invonlved. $\endgroup$
    – kamran
    Feb 17, 2022 at 18:40
  • $\begingroup$ Ah ok thank you!! So the above calculations from your answer will be all I need. So I will only need the torque due to angular acceleration if I'm understanding correctly? $\endgroup$
    – user36991
    Feb 17, 2022 at 18:47
  • $\begingroup$ yes, as long as you measure the arm length from its hing and keep the motions separate you're fine. $\endgroup$
    – kamran
    Feb 17, 2022 at 20:05
  • $\begingroup$ So, T=a*I, where I has been calculated to be 0.027Nm^2 from your calculations. To find a, I will need to specify how fast I want the arm to turn to a specific angle? Is that correct? $\endgroup$
    – user36991
    Feb 17, 2022 at 20:39
