I have a large boom of a radio antenna weighing $3,500 kg$ which is rotating at $0.5 RPM$. The antenna is a T shape and the boom radius is $14m$. The power to the motor is cut off suddenly and the motor acts as a rigid brake. The boom is not rigid and it continues to move/bend in the same direction for 1 second (at which points it bounces back and fourth until the forces damper out). I am trying to work out the max torque this would apply to the gearbox shaft, assuming there is no friction.
For angular movement, I have designated the centroid of each boom radius as a point load (so a point load at a radius of 7 m on both ends of the boom).
I can work out the angular moment which is $m \cdot r \cdot v$, which works out to $1750 kg \cdot 7m \cdot 0.367m/s$ or $4489.86kg\frac{m^2}{s}$
This is where I am not sure about though. I have read that torque is simply the change in angular momentum over time. So would that be $4489.86kg\cdot m $ $(44.1kN \cdot m)$?
Would this be an accurate way to determine the torque in the shaft? This is for a real scenario so If I have missed any big considerations please let me know.
