I see these frequently on tall power lines like the one in the image below, sometimes a single one at each end, sometimes pairs as are shown here. Sometimes on one side of the tower but not the other.
I vaguely remember reading once that they are used to reduce swinging in high winds, and where I live typhoons come regularly.
  1. What are these called?
  2. Are they used to reduce swinging in high winds?
  3. How do they do this?
  4. When is a pair used instead of a single; why not just use a bigger one?
From Wired original: https://i.sstatic.net/pLy9u.jpg
According to the wiki, these are called Stockbridge dampers. The design is tuned for a specific length and one might also expect a specific mass/material.
The weights are mounted on flexible arms, typically a length of stiff cable, which allow the assembly to absorb energy that might otherwise be imparted to the longer power lines, or more accurately, that kinetic energy (movement) is removed from the lines, preventing oscillation.
Directly from the wiki:
The Stockbridge damper targets oscillations due to aeolian vibration; it is less effective outside this amplitude and frequency range. Aeolian vibration occurs in the vertical plane and is caused by alternating shedding of vortices on the leeward side of the cable. A steady but moderate wind can induce a standing wave pattern on the line consisting of several wavelengths per span. Aeolian vibration causes damaging stress fatigue to the cable and represents the principal cause of failure of conductor strands. The ends of a power line span, where it is clamped to the transmission towers, are at most risk. The effect becomes more pronounced with increased cable tension, as its natural self-damping is reduced.
  • $\begingroup$ Oh, vortex shedding! So these are important during normal wind conditions rather than only extreme conditions like typhoons. Simply knowing what they are called helps a lot, thanks! $\endgroup$
    – uhoh
    Commented Jan 10, 2020 at 4:22
In order to supplement @fred_dot_u's answer and add a few details on the nature of the problem that these devices address I'll add a bit of additional material.
For a description of a numerical model of how Stockbridge dampers work and ANSYS simulation results, see for example Aeolian vibration of a single conductor with a Stockbridge damper, Oumar Barry, Donatus CD Oguamanam and Der Chyan Lin, Proc IMechE Part C: J Mechanical Engineering Science, 227(5) 935–945, DOI: 10.1177/0954406212452064
Also, from J-L Lilien's Power Line Aeolian Vibrations.
Aeolian vibration is a low amplitude (conductor diameter) high frequency (5 to 150 Hz) phenomenon. Aeolian vibration is one of the most important problems in transmission lines because it represents the major cause of fatigue failure of conductor strands or of items associated with the support, use, and protection of the conductor. In this phenomenon, conductor strand fatigue failures occur at the suspension clamps or at the clamps of the other devices installed on the conductor such as spacers, spacer dampers, dampers and other devices.
Fig 2.1 typical broken strand due to aeolian vibration after removal of suspension clamp
Fig 2.1 typical broken strand due to aeolian vibration after removal of suspension clamp.
Forces induced by vortex shedding are the cause of this type of vibration (Blevins1990, Buckner 1968, Claren et al 1969 & 1974).
Fig 2.2 Flow visualization of vortex shedding
Fig 2.2 Flow visualization; identification according to (row, column): (1,1) R=1.1 (Taneda), (1,2) R=9.6 (Taneda), (2,1) R=26 (Taneda), (2,2) R=140 (Taneda), (3,1) R=2000 (Werlé & Gallon), (3,2) R=10000 (Corke & Nagib)
The fatigue mechanism
The fatigue in power line conductors are caused by fretting between different layers of strands at their contact area (fig 5.1). Some cracks appear and propagate. The stick/slip elliptical contact area is depending on the radius of curvature taken by the conductor. During alternating bending stress (due to oscillations) that radius of curvature is changing continuously. It is particularly important near clamp ends at the last point of contact.
Fig 5.1 the inter-strand contact area where first crack may appear (Epri-1979)
From Aeolian Vibration Basics
Figure 14 – VORTX™ Damper
Figure 16 – Damper Response Test Set-Up
Figure 17 – Damper Response Curve
Figure 17 – Damper Response Curvee
Figure 17 shows the power (in watts) delivered to the damper by the shaker (vertical axis) over a range of frequencies. The results are shown for three of the same damper design, along with the average. This plot shows four distinct peaks in the power curve. These represent the resonant frequencies of the damper weights. Each weight has two resonant frequencies: one where the furthest end of the weight has the maximum movement, and the other where the end nearest the clamp has the maximum movement (higher frequency). The VORTX Damper shown in the curve has two different weights, each with different resonant frequencies, which accounts for the four peaks in the curve
