I want to pull some weight horizontally and for that i have settled for a linear actuator.
The actuator should pull some weight as it moves back and forth as the gif shows.
There are linear actuators i could find but they are too bulky with heavy motors and a lot of lubrication and the noise they make is not music to my ears.
I found electrical actuators to be a perfect fit but i do not know how they work for instance this actuator: R4 Series
  • $\begingroup$ Look into ultrasonic motors. I don't know if there are any in trade for such "generic application" but they can be entirely silent, very compact and provide surprising amount of force for their size. $\endgroup$
    – SF.
    Nov 28, 2017 at 13:18
I found these images. Looks like they are driven by a motor.
Belt Driven Model
Belt Driven Model
Screw Driven Model
I suggest reviewing this document
For a minimum of moving parts, you can get linear stepper motors. With the right kind of controller (microstepping), the motion can be very smooth and quiet.
For example, I have in the past worked with linear actuators from Nippon Pulse, driven by a motor controller from Technosoft. Very precise and powerful, but also very expensive!
  • $\begingroup$ Dave just out of interest, how much roughly would we be talking for the smallest linear servormotor from Nippon Pulse? $\endgroup$
    – user88720
    Jan 16, 2016 at 19:38
  • $\begingroup$ @user88720: I didn't do the purchasing, so I'm not too sure. We used a couple of medium-sized dual-rail ones (500 mm travel) that I believe cost somewhere in the neighborhood of $2500 each. Way too costly for our end application, but we wanted the precision and the ability to experiment with different algorithms in our research prototypes. $\endgroup$
    – Dave Tweed
    Jan 16, 2016 at 19:55
  • $\begingroup$ Fair enough. When I noticed they had a precision down to the nanometer, I got the feeling they were going to be pretty expensive. Too expensive for my application as well :( $\endgroup$
    – user88720
    Jan 17, 2016 at 0:59
