Consider $$\hat{G}(s) = \frac{1}{s^2+s}$$ than the Nyquist plot is
In both plots it seems that the closed-loop system is stable even when the eigenvalues are {0, -1}. For a higher order closed-loop system one can see that a system like
$$\hat{G}(s) = \frac{1}{s^3+s^2+s}$$
is at its stability limit since ne Nquist plots hits the real axis at -1 and in the Bode plot there is no phase reserve when magnitude hits 0. Why dose the Nyquist and the Bode plot fail for a closed-loop system of 2nd order?
