I'm working on a project to design a shell and tube heat exchanger. There's a mixture of 68.4% C,3H6 and 31.4% C3H8 being cooled from 135 $^\circ$F and 321 psia to 100 $^\circ$F and 285 psig. The volumetric flow rate of the hydrocarbon stream is 200 GPM. The cooling water on the outside is initially at 85 F and 60 psig and exit pressure of 50 psi.
I'm not sure if my process is correct, but I found the average of the inlet and outlet pressure and temperature in the hydrocarbon stream and then used those values in the ideal gas equation to find the densities of each hydrocarbon, I then took the average of the two densities and multiplied by the volumetric flow rate to find the mass flow rate of the hydrocarbon stream. I was then going to use the equation $$Q =m^o C_{p1} (T_2-T_1)(0.684) + m^oC_{p2}(T_2-T_1)(0.314)$$ to find the heat transfer of the hydrocarbon stream and then balance it with the water stream. I'm not exactly sure how to find the specific heats of the hydrocarbons. I checked perry's handbook but couldn't find anything at the average temperature. I'm just looking for any advice on whether or not this would be a correct procedure and if so, where could I find the specific heats of the hydrocarbons.
