I'm simulating different arrays for cylinders in a simple cross flow heat exchanger (cylindrical pipes) as shown below:
Inlet temperate(300K) is constant and the cylinders are at constant temperature(400K).
I'm simulating different arrays for cylinders.
I've calculated average Nusselt on each pipe then summed all of them and finally divided it by the number of cylinders (9).
This gives me an average Nusselt number for heat exchanger. Let's call it $Nu_{av}$. $Nu_{av}=\frac{\sum Nu_{cylinder}}{9}$
I also calculated the heat transfer coefficient of heat exchanger using the following equation: $\dot{m}c(T_o-T_i)=UA(T_s-T_i)$
$\dot{m}$: Mass flow of fluid passing the heat exchanger
$c$: Specific heat of fluid
$T_o$: Average outlet temperature
$T_i$: Average inlet temperature
$U$: Heat exchanger coefficient
$A$: Total surface of all cylinders
$T_s$: Cylinders surface temperature
I've simulated a lot of arrays. In some cases, the average Nusselt number($Nu_{av}$) is bigger and in some others, the average outlet temperature and so, the heat exchanger coefficient($U$) is bigger.
My question is: Which one should be my criteria to compare cases? Average Nusselt number or heat exchanger coefficient?
