First post here.
I'm an undergraduate ME interested in fluid mechanics. I came across scramjets and I was interested about the engine. I want to calculate the mass flow rate of the engine and I made an attempt because it doesn't seem right and I can't find any resource explaining how to calculate the mass flow rate of a scramjet.
I arrived at this using standard definitions: $ \dot m = (\frac {P}{RT}AM\sqrt{\gamma RT}) $
where $P$ is the absolute pressure of free stream (air, in this case)
$R$ is the gas constant for air
$A$ is cross sectional area
$M$ is the Mach number
$T$ is absolute temperature
$\gamma$ is ratio of specific heats
I'll be honest, I have no strong intuition about this since I'm only a junior undergrad who only has taken Thermo and Fluids (no heat transfer yet, compressible flow not in curriculum) but if you guys can steer me in the right direction I would be very happy. I sense that it should be more geometry dependent, maybe angle of attack should be considered as well?
Thank you everyone!
