Diagram of Mecanism
I have a wheel with a diameter of 2m and a weight of 67kg. The wheel has a radius of gyration of 0.82m. From this wheel a weight of 35kg is suspended. The weight will fall for 10m and accelerate the wheel. Connected to the shaft of the wheel is a sprocket of diameter 0.3m over which a chain with a stop runs. The stop on the chain hits a spring that will break the fall of the 35kg weight and the inertia of the wheel. The spring is 25cm long and compresses 10cm. What is the force acting on the spring?
What would be the right approach to solve this question?
My attempt:
  1. I calculated the the energy of the free fall of the weight
  2. I calculated energy of the rotating wheel
  3. I then summed up both linear and rotating energies and used the compression distance of the spring to get to the required force.
This resulting force seems awfully high. Any suggestions? Thanks!
Here is my attempt:
  1. I calculated the the energy of the free fall of the weight through $E = \frac{1}{2} m v^2$ using the final velocity of the free fall (I did not know how to consider the initial inertia of the wheel though).
    $g=10m/s^2$ [gravity]
    $H=10 m$ [free fall height]
    $t = \sqrt{\frac{2H}{g}}= 1.4s$ [time free fall]
    $vmax = gt = 14.1m/s $ [velocity after t]
    $m1 = 35kg$ [mass of falling object]
    $E = \frac{1}{2} m v^2 = 3.5kJ$ [energy after t]
  2. I calculated energy of the rotating wheel $K = \frac{1}{2} I \omega^2$
    $r1=1m$ [radius of wheel]
    $w=\frac{v}{r} = 14.1/s$ [angular velocity]
    $m2 = 67kg$ [mass of wheel]
    $r2 = 0.82m$ [radius of gyration]
    $I=m2*r2^2 = 45kgm^2$ [moment of inertia wheel]
    $K=\frac{1}{2}Iw^2 = 4.5kJ$ [rotational energy wheel]
  3. I then summed up both linear and rotating energies and used the compression distance of the spring to get to the required force. $E(total) = 8.0kJ$
    $d = 0.10m$ [spring length compression]
    $F=\frac{E}{d} = 80kN$
  • $\begingroup$ Show your calculations so people can offer corrections / comments. $\endgroup$
    Commented Jan 9 at 15:59
  • $\begingroup$ I just updated my question and added my calculations. $\endgroup$
    – Mecky
    Commented Jan 9 at 17:02
If the weight is in free fall, it cannot transfer energy to the wheel. From energy perspective, the input is potential energy of the 35 kg weight at the 10 m height. $$E_{in} = m\cdot g\cdot h$$ Neglecting loses, this is the energy that will have to be stopped by the spring. $$E_{out} = \frac{1}{2}\cdot k\cdot u^2$$
Equating the energies: $$m\cdot g\cdot h = \frac{1}{2}\cdot k\cdot u^2$$
Substituting the spring force $F = k\cdot u$ into the energy equation: $$m\cdot g\cdot h = \frac{1}{2}\cdot F\cdot u$$
From this, the maximum force is: $$F = \frac{2m\cdot g\cdot h}{u}$$
The force in your case is about 69 kN.
  • $\begingroup$ Hi Tomás, thanks for your answer. The 35kg is actually attched to the wheel by means of a wire rope and will accelerate the wheel and drop 10m. How would I account for that? $\endgroup$
    – Mecky
    Commented Jan 9 at 17:04
  • $\begingroup$ You need to focus on starting and ending point, it does not matter what goes on in between unless you want to take into account loses. When the weight accelerates the wheel, it will do so at the expense of its own energy. $\endgroup$ Commented Jan 9 at 18:17
