![enter image description here
Here, $P>Q$. $O$ is the center of mass of the rigid and uniform bar/stick.
As $P>Q$, the resultant is situated to the right of $\vec{P}$ and is parallel to $\vec{P}$. The magnitude of the resultant is $P-Q$.
To convince you that the figure is correct, I'll do some math to prove it.
Let us obtain the sum of torques about the center of mass,
$$(P-Q)b=Pa+Qa$$
$$b=\frac{P+Q}{P-Q}a$$
$$b=fa\ \left[\text{Let $f=\frac{P+Q}{P-Q}$}\right]$$
As $P>Q$, $f>1$, and $b>a$. So, the correct figure will be,
I hope you're satisfied that the figure is correct.
My comments:
Is it possible to replace $\vec{P}$ and $\vec{Q}$ with a single force? I mean practically, not theoretically. From the figure, we can see that the resultant force is outside the bar. In other words, $\vec{P}$ and $\vec{Q}$ can be replaced by a force of magnitude $P-Q$, which will act outside the bar. This may be possible theoretically; however, this is not possible practically as the resultant force will be acting on literally nothing as it is outside the bar. Therefore, I conclude that it is impossible to replace $\vec{P}$ and $\vec{Q}$ with a single force practically. Theoretically, it is possible, but practically, no.
My question:
  1. Can $\vec{P}$ and $\vec{Q}$ be replaced by a single force? Is my conclusion correct?
These may help you to answer this question:
  1. Comment by @Ivan
  2. Answer by @Farcher
This question was posted with the help of @Eli.
  • $\begingroup$ Crossposted from PSE and MSE $\endgroup$ Commented Mar 23, 2022 at 5:12
    $\begingroup$ The question has an answer that is linked to in the question. $\endgroup$
    Commented Mar 23, 2022 at 6:57
As you have calculated the torque on the bar is
$$\tau= (P+q)A$$
and a net force
$$F=P-Q$$
This will cause the bar to turn with an angular acceleration,
$$\alpha=\frac{\tau}{I}$$
and also accelerate with,
$$a=\frac{P-Q}{m}$$
Any substitute pair of forces acting within the length of the bar can be scaled by the factor of $A/D$ to impart the same torque. But the new net force will not be the same.
$P_N-Q_N\neq P-Q$.
  • A= half-length of bar
  • m= mass
  • a= linear acceleration
  • D = distance of new pair of force Pn, Qn, from the center of the bar
  • $\alpha$= angular acceleration
  • I= bar's moment of inertia
  • $\tau$= torque
So depending on what you demand the answer varies, if you require just the same torque, yes. If you require the same torque and linear acceleration no!
