If I am to make a block using the materials for making paper, what would its compressive strength be? I am interested in not the stacked paper test, but using the same material in a block form since I do not believe they will fail the same way (or if you think otherwise, please explain your logic behind your deductions).
In terms of the material of paper, I am pretty flexible. The ideal will be a range of papers with shorter fibers and less interfiber connections, and papers with longer fibers and more interfiber connections.
