I have been thinking for years about building an outside stair / loft ladder to climb from a platform to another one, one stair higher (3 meters). However, I never studied material strength, and I don't know anything about how to calculate my needs. Especially since talking with a friend, he mentioned that aluminium becomes brittle in cold weather and he has witnessed multiple accidents with ladders breaking in cold weather.
Here is the kind of material I wanted to buy
profile measurements
or
And here is the strength data
enter image description here What do those mean, where can I find resources to (learn to) use those, and how should I add correction related with temperature variations?
Aluminum is generally not subject to low temperature embrittlement, unlike steel. Some alloys are used at cryogenic temperatures. Here is some very general information on low temperature properties. I don't think low temperatures are causing aluminum ladders to break. You should be able to find strength data as a function of temperature for any alloy you might be considering from an aluminum supplier.
Ferritic steels ( the magnetic stuff ) are the only metals that may have a severe toughness loss ( brittle) at low temperatures. As the temperature drops the ductility of all metals tend to be lower but not the potentially sharp reduction of toughness like a ferritic transition. Your aluminum ladder will become slightly stronger in cold weather; don't drink what your friend is drinking.
