I drew a puzzle like joint sketch and split a body with it for 3d printing.
But I have to add a small gap between them for the tolerance of the machine.
Any way on how to do it not manually?
Use a thin cut extrude, instead of the "Split" tool.
Set this to be midplane, and add the total tolerance gap that you require depending on your printer, and how loose you want the puzzle pieces to be.
