Attached is a plot of amplitude vs frequency and on the inset phase vs frequency. I have constructed this phase plot via $\arctan\left(\frac{Im}{Re}\right)$
How can I interpret the phase plot or extract some meaningful info from it, particularly in the region of the almost vertical line? This line occurs at around 102Hz which is nowhere near the amplitude peaks.
  • $\begingroup$ What is the system you present the amplitude vs frequency plot? Is it some rotating shaft? $\endgroup$
    – NMech
    Commented Oct 22, 2020 at 10:08
  • $\begingroup$ mounted on a bracket as part of engine assembly $\endgroup$ Commented Oct 22, 2020 at 10:32
  • $\begingroup$ This has been common technology for rotating equipment for decades . I think you could find more analysis information under "rotating machinery"' $\endgroup$ Commented Oct 22, 2020 at 14:39
I'm not an expert, but that vertical line in the phase is usually when transitioning over a critical rotational velocity of a shaft.
This happens when the excitation frequency "transverses" the critical frequency of the shaft. The displacement of the shaft can be derived for an ideal motor (no damping):
$$ y = \frac{e\cdot \omega^2}{\omega_n^2 - \omega^2} = \frac{e}{\frac{\omega_n^2}{ \omega^2} - 1} $$
while a more advanced approach, with the inclusion of damping, calculates the dynamic magnifier as :
$$H(r,\zeta) = \frac{r^2}{\sqrt{(1-r^2)^2 + (2\zeta r)^2}}$$
the phase angle can be estimated by a similar expression as:
$$\phi = \arctan\left(\frac{2\zeta r}{1- r^2}\right)$$
where:
  • $\zeta$: is the damping ratio
  • $r=\frac{\omega}{\omega_n}$
So when passing through the natural frequency $\omega_n$ what happens is that :
  • (usually )you get a maximum value of the displacement
  • you get an inversion of the phase angle $\phi$ (the ratio becomes greater than 1).
So what you are seeing in this graph at about 115[Hz]$\approx 6900rpm$, is that you pass through the critical speed of the shaft.
The earlier peak (at about 95Hz) is probably another natural frequency of the engine assembly.
  • $\begingroup$ Thanks for this insight. The frequency range is fron a “run down” speed sweep. So perhaps we are passing through shaft natural frequencies which is picked up on the bracket. $\endgroup$ Commented Oct 22, 2020 at 14:44
