Let's assume a DMM is specified to have accuracy "0.1% FS +/-0.02" when used on the 50 V range.
I get that 0.1% FS means the true value will lie somewhere between measured value - 0.05 and measured value + 0.05. But what does +/- 0.02 mean here?
The ±0.02 is an additional uncertainty voltage that needs to be added, regardless of the full scale value.
So you would end up with "measured value" ± 0.07 V on the 50 V range.
