I want to replicate the kind of interface you see on inboard boats, pumps, or food blenders. Basically, I want put a motor in a sealed vessel, and have it turn a prop outside the vessel, in water.
Is this usually done just with a layer of grease over a bearing? Are there any alternatives?
  • $\begingroup$ The shaft going to the propellor on a boat goes through a bearing or bearings and seals... $\endgroup$
    Nov 11, 2019 at 10:01
  • $\begingroup$ I found the name on one of your other answers - essentially I want to build a stuffing box. $\endgroup$
    – Alex
    Nov 11, 2019 at 13:01
  • $\begingroup$ The term you want to search on is "rotating seal" (avoid the pages on dancing marine mammals). A stuffing box is one sort of that larger category. $\endgroup$
    – TimWescott
    Nov 11, 2019 at 16:01
  • $\begingroup$ That's what I was after, thank you $\endgroup$
    – Alex
    Nov 11, 2019 at 17:53
The seal you are looking for is commonly called an oil rotary seal ring.
I found many brands and sizes with a quick search.
the range of prices for a 1-inch shaft is around $5.
oil rotary seal
