Let's say we have a flat object. We are asked to create some mechanism so that the part can rotate in the shown angles above. What mechanisms can be used?
Gimbals are the classic solution for this: https://en.wikipedia.org/wiki/Gimbal And if you don't need any roll, you can omit one of the gimbal rings, in which case a pan/tilt mechanism is sufficient (often sold for photography.) You might look for a gimballed gyroscope toy and start with that. (Flight quality gimbals are expensive.)
$\begingroup$ Link only answers are considered poor on this stack, due to link rot. $\endgroup$ Commented Jul 7, 2019 at 18:47
$\begingroup$ (1) it's a Wikipedia link to a non-controversial subject, so I suspect it'll be there longer than anybody reading, and (b) even a dictionary will return something useful for the user if they know the name of the mechanism. YMMV $\endgroup$– CatalystCommented Jul 7, 2019 at 18:50
$\begingroup$ @SolarMike He has not yet come up with number 2. I guess the number one has two subsegment:) $\endgroup$– user14407Commented Jul 7, 2019 at 19:42
$\begingroup$ @SamFarjamirad he started with (1) then used (b) ... $\endgroup$ Commented Jul 7, 2019 at 19:44
You can mount your head part on a neck globe with two pins protruding out and screw that into a sphere socket like a kids doll neck.
This spherical socket is threaded in a pitch that spirals around the sphere with the slope of 30 degrees over a half a turn and the two pins slide back and forth in this thread.
