In order to give you a good idea of what I want to accomplish suppose you have a telescope mounted on a single rod extruding from the ground. The telescope is free to move such that you can tilt it to point at a particular altitude but can never point towards the ground. In order to move the telescope you have a wheel which can only be rotated in a single direction (say clockwise). Is there a gear configuration that would make a point alternate rotations every 180 degrees? and also have it configured such that the power loss is consistent throughout the entire cycle so that no half a cycle takes more power than the other?
Here is an illustration
