I have been trying to calculate the analytical solution for the following problem but have not succeeded to reach an exact solution. Can anyone propose a way?
A concrete beam is to be lifted by two cranes. The beam is 20 m long and weights 900 kN. The cranes have lifting capacities of 500 kN and 400 kN. What are distances $a$, $b$, and $c$ in the scheme below so the cranes are not overloaded? (position of cranes are marked with | |)
<---- a----> <----- b -------> <--- c --->
=========================================== <-- the beam
A = 500 kN B = 400 kN
- A & B: reaction forces of cranes
- distributed self weight q = 900 kN / 20 m = 45 kN/m
- $a + b + c = L = 20\text{ m}$
The beam is statically determinate.
My attempted solutions:
I started from the equilibrium equations of the sum of bending moments about the left and right ends which are equal to zero:
$$\begin{align} \sum M_{left} &= 0 = Aa + B(a + b) = \dfrac{qL^2}{2} \\ \sum M_{right} &= 0 = Bc + A(b + c) = \dfrac{qL^2}{2} \end{align}$$
A third equation is needed; I have tried $a + b + c = L$, but I arrive at the "apple = apple" situation, which implies that the three equations are not independent.
I also tried to add an additional constrained by putting any of the $a$, $b$ or $c$ values equal to a constant value. The issue then is that each of the equilibrium equations become dependent on only one of the two remaining unknowns, as in the following case, where I have put $b = L/3$:
$$\begin{align} \sum M_{left} &= 0 = \dfrac{qL^2}{2} = Aa + B(a + L/3) \\ \sum M_{right} &= 0 = \dfrac{qL^2}{2} = Bc + A(c + L/3) \end{align}$$
And thus, each solved unknown will not satisfy the other equilibrium equation.
I have run out of tricks in my sleeve ...
