I would like to double the shear capacity of an I beam by welding some steel plates. What strengthening schemes are available? How would you define the shear area for the strengthening scheme proposed?
$\begingroup$ Duplicate of : engineering.stackexchange.com/questions/15547/… $\endgroup$ – Solar Mike May 29 '17 at 5:27
$\begingroup$ @SolarMike, my question here is for shear strengthening, the other question is moment strengthening. These are two different question. $\endgroup$ – Jarard May 29 '17 at 5:40
$\begingroup$ Apply what you have been given then - and check out the applicable theory $\endgroup$ – Solar Mike May 29 '17 at 5:50
-2
The web have almost all the resistance to shear. I recommend to review the basic texts of mechanics of materials, such as that of James M Gere.
2$\begingroup$ Please put any required information in your answer. A recommendation to a book does not help very much. The answer should mainly stand on its own. $\endgroup$ – hazzey♦ Nov 8 '18 at 1:51
