Hope you all are doing good.
Can anyone please guide me on how to calculate the different torques at the base as shown in the image?
Thank you for your time and help.
let's say your boom's moment of inertia about that rotation axis is $\ I_{boom}, \quad$ and the load is at distance R and weighs m.kg so $I_{load}=m*r^2$.
$$I_{total}=I_{boom }+I_{load}$$
Torque is change of angular momentum, $L=I\omega \quad$ call the torque $\tau \ \text{and angular acceleration}\ \alpha $ The boom turns with an angular acceleration $\alpha$ to go from $\omega=0\ to\ \omega_{operation}\ $
Then torque is:
$$\tau=I_{total}*\alpha$$
If by holding torque you mean stopping the boom after it has rotated and reached the target, brake torque, the Torque is again the same.
$\tau= I_{total}\alpha$
This time $\alpha$ can be larger depending on how fast the brake can stop the boom safely.
When the basket is already stopped there is need for a locking mechanism like a ratchet or a brake.
let's say the truck bed is at an angle a and the boom is extended perpendicular to the truck.
we treat the boom and its load in the basket as a cantilver beam with its weight and the load P multiplied by sin(a). So the torque to hold position is
$\tau=sin(a)[(m_{boom}L_{boom}/2)+PL]$
we should add a factor of safety
At any static position, the operating arm will exert a bearing force P and an overturning moment on the unit, these forces are countered by the weight and the reactions on the wheels.
Depending on the type of bearing, the operation of the arm will produce a horizontal force required for 1) locking the bearing at a steady position, and 2) changing the position of the bearing for new reaches. The torque required for the latter case is straightforward as $T = f_Pd_P$; the torque required for the former case needs to take into account the dynamic forces induced by the upper components.
Note, the mechanisms shown are suggestive only.
