I am trying to find out the differences between the model-based control approach and the data-driven one.
Surely the main difference is the latter's independence from the information of the mathematical model of the plant in the control design.
For the former from experimental data a model for the plant is obtained with some degree of accuracy.
If for data-driven techniques, I have found out many examples: PID, IFT, ILC, etc., I have not found out anything for the model-based control. Can you give me some examples of techniques (maybe the most common) that can be defined as model-based control approaches?
