calculation of exit temperature
The heat transfer rate between $\dot{Q}$ oil and water should be equal to the change in heat capacity in the medium.
$$\dot{Q}= m_oC_{p,o}\delta T_{o} = - m_wC_{p,w}\delta T_{w}$$
you can solve this algebraically and obtain:
$$ 2.27 \cdot 2198 \cdot(150−40)= 1.36\cdot 4187 (T_{wo}−21)$$
$$ T_{wo} =\frac{2.27 \cdot 2198 \cdot(150−40)}{ 1.36\cdot 4187} +21 [^oC]$$
if my numerical calculations are correct this should be:
$$T_{wo} = 117[^oC]$$
LMTD method
For a counter flow heat exchanger the heat transfer rate $\dot{Q}$ is equal to:
$$\dot{Q} = kA\cdot\Delta T_{lm}$$
where:
- The $\Delta T_{lm}$ is the temperature difference for counterflow, which is given from the following equation.
$$\Delta T_{lm} = \frac{\Delta T_1-\Delta T_2}{\ln (\Delta T_1/\Delta T_2)}$$
For this particular example
- $\Delta T_1 = T_{o,i}-T_{w,o} = 150-T_{w,o} = 33$ : temperature difference at one exit (at the center of the drawing)
- $\Delta T_2 = T_{o,o}-T_{w,i} = 40 -21=19[C] $ : temperature difference at other Exit (bottom of the drawing).
Because $\dot{Q}= m_oC_{p,o}\delta T_{o}$, it is possible to calculate k for LMDT method as:
$$ k_{ry}= \frac{\dot{Q}\ln (\Delta T_1/\Delta T_2)}{A(\Delta T_1-\Delta T_2)} $$
$$ k_{ry}= \frac{\dot{Q}\ln (33/19)}{A(33-19)} =21642 \frac{1}{A} [\frac{W}{m^2*K}] = \approx 904[\frac{W}{m^2 K}]$$
A is the exchange area and its $A = 60\cdot 2\cdot \pi\cdot r_{tube}$.
NTU method
Maximum possible heat rate $q_{max}$
$$q_{max} = C_{min} (T_{o,i}- T_{w_i}$$
where:
- $ C_{min} = m_oC_{p,o} = 4989.46$
- $T_{o,i}= 150 [^oC]$
- $ T_{w_i}= 21 [^oC]$
The effectiveness is defined as:
$$\epsilon = \frac{\text{Actual heat transfer}}{\text{max heat transferred}}$$
$$\epsilon = \frac{ m_oC_{p,o}\delta T_{o}}{4989.46(150-21)}$$
However $\epsilon$ for a parallel flow can be given from equation:
$$\epsilon = \frac{1- e^{- NTU \cdot (1-c)}}{1- c\cdot e^{-NTU \cdot (1-c)}}$$
where $c = \frac{C_{min}}{C_{max}} = 4989.46/5694.32=0.8762$
Substituting should get you
$$\epsilon \approx 0.8527$$
solving for $NTU$ should get you:
$$NTU = \frac{\ln(\frac{\epsilon - 1}{c*\epsilon - 1})}{c - 1} = 4.3654$$
From there, because :
$$ NTU=\frac{UA}{C_{min}}$$
you can solve for U:
$$U = =\frac{NTU \cdot C_{min}}{A}\approx 909[\frac{W}{m^2 K}]$$
