I ordered this model:
I downloaded this diagram to get a better idea of the parts(This from a different model but they share a majority of components):
I'm just curious about the 1-10 knob on the back that puts a metal pad either closer or farther away from the device. I assume this varies the magnetic resistance
I'm also curious about the back-tension button. I see that when you tighten the screw the tension arm takes more pressure to pull down.
All-in-all, I just want to know how the knob on the back works in conjunction with the back-tension
Also, If you've used a Coil winding magnetic tensioner before, any info on its functions I would love to learn about.
I'm reaching out because there is basically nothing online about how these things work and all the labels on my tensioner are in Chinese so I'm clueless
