I saw a story on CNN today about a figure-eight ferris wheel being built in Macau.
I'm curious what path the cabins take, and how this occurs. Do they actually follow a figure eight pattern? Do they move from one wheel to the other somehow?
The story has a picture with the caption
The cabins don't actually cross in the middle. They follow a gourd-shaped track. Each ride takes around 15 minutes.
I don't understand what that means. A "gourd-shaped" track?
  • $\begingroup$ gourd, though you can also visualize a stylized hourglass $\endgroup$ Nov 5, 2015 at 21:55
  • $\begingroup$ @DCShannon Some gourds (such as this one) are an excellent description for the shape of the track. Others (such as this one) not so much. $\endgroup$ Nov 5, 2015 at 22:09
10
It looks like the cars don't actually move in a figure eight, though it is designed to look like they do from afar. In the image below you can see that the cars travel around an hourglass-shaped (or gourd-shaped) track which is behind the outer yellow steel structure that looks like a figure eight.
They describe the track as gourd-shaped because some gourds, such as the one shown below, describe the shape of the track very well even though others do not.
