In question 3-37,we have P-p(ATM)=density * g* h and we get h as 8.3 m But the answer is 1.53 m.How and why?What is wrong in my approach?
2$\begingroup$ What value did you use for the density of mecury? $\endgroup$ – Solar Mike Mar 9 '18 at 7:01
$\begingroup$ The thought that a doctor's office would put on a BP cuff and then dump my vein into that apparatus is frightening, to say the least! $\endgroup$ – Carl Witthoft Mar 9 '18 at 16:14
$\begingroup$ @CarlWitthoft only have to go back a couple of hundred years and blood-letting was a « current » treatment... $\endgroup$ – Solar Mike Mar 9 '18 at 16:25
$\begingroup$ @SolarMike in your childhood, then? $\endgroup$ – Carl Witthoft Mar 9 '18 at 18:46
$\begingroup$ I have taken it as 13600 kg/m^3 $\endgroup$ – Shwetha Mar 23 '18 at 4:02
Add a comment
Pressure due to mercury is: Pm = 13600*9.81*0.12 = 16010
So, that is the pressure created by the blood and it will then rise:
hb = 16010/(1040*9.81) = 1.57m
Obviously, I have used constants I am aware of - subtle differences will give 1.53m...
Edit the density of mercury is 13560kg/m3 so that is where my error comes in...
$\begingroup$ Then please accept the answer by using the “tick” .... $\endgroup$ – Solar Mike Mar 23 '18 at 5:17
