For a National Board Exam Review:
A floating cylinder 8cm in diameter and weighing 950 grams is placed in a cylindrical container 20cm in diameter and partially full of water. The increase in the depth of water in the container due to placing the float in it is:
Answer is 3cm
So I try:
$${ P_1 = \frac{0.950kg * 9.81 \frac{m}{s^2}}{ \frac{\pi}{4} * { (20cm * \frac{1m}{100cm}})^2 } = 296.649 \frac{N}{m^2}}$$
$${ \gamma = 9.81 \frac{kN}{m^3} }$$
$${ P_2 = P_{atm} = 101325 \frac{N}{m^2}}$$
$${ P_1 + \gamma h = P_2 }$$
$${h = 10.29m }$$
What is my error? Am I using wrong approach? Wrong formula?
