So, this is the truss I have to solve, more precisely I have to find forces in all of the members of the truss. That is why I used method of joints. I started from the joint A and realised without calculating that members attached to it (Fab and Fal) are the zero force members.
enter image description here PICTURE ON THE LEFT: After that I continued the process with joint B and calculated forces in members Fbl and Fbc. If I have made a mistake here, I will appreciate you also point that out.
PICTURE ON THE RIGHT: The only joint with 2 unknown members that has left after calculating members of joint B is joint L. But here is the problem. Since I can only use 2 equations - sum of the forces in the X and Y direction (in method of joints), I don't know how to find Flk and Flc, since those are not neither vertical nor horizontal forces. I know I should split those into their components (vertical and horizontal), but since they are both unknown members (so are the components), I don't see way to calculate any of them.
I cannot view your image clearly, but your problem is solvable:
Let me try to explain.
Since FBL is known (FBL = 45 tension), the remaining members are FLK and FLC. You need to find the inclination of FLK. Solve for angles A and B in this image,
Summing up forces along Y gives equation:
FLK (sin A) - FLC (sin B) - FBL = 0
Summing up forces along X gives equation:
FLK (cos A) + FLC (cos B) = 0
Then solve the two equations using either: Method of elimination, Method of substitution or by calculator. Please refer to your algebra notes for this :)
Let me give you the first step of Method of Substitution:
FLK = - FLC (cos B) / (cos A)
substitute in the first equation to solve FLC.
Hope this helps.
