For reinforcing in concrete, anchorage / lap lengths are determined by the multiplying the diameter of the rebar with a factor. Generally a factor of 40-45 is accepted as the de-facto standard. According to EC2, the factor falls within the range from 34 and 66, depending on concrete quality, etc.
It is my understanding that the factor is in linked to the amount of shear resistance required to act against a force pulling out a rebar at its ultimate tensile stress. The factor is thus the height of the shear cone created.
When lapping a bar of larger diameter with a smaller one, my explanation above would be used to argue the case that the smaller diameter is taken to determine lap length.
I have found various sources where people have said the smaller bar should be used. I can find no code references defining it though. I would assume that one goes for the larger diameter to be safe, but the extra steel obviously increases cost.
Any advice would be greatly appreciated.
The use of the smaller diameter is theoretically correct.
What is a splice? It is when tension force in a rebar is transferred to the concrete via adhesion and then to another rebar. Since concrete is very weak against tension, large lap lengths are required such that the stress at any point in the concrete is not excessive. However, once the splice is over, all the tension from the first rebar has been transferred to the other one, which must also be capable of withstanding that same tension.
Therefore, if you are splicing two rebars of different diameters, the maximum tensile force that can be transferred via the splice is equal to the yield strength of the smaller rebar. If the tensile force is larger (say, equal to the yield strength of the larger rebar), then the smaller rebar will rupture immediately after the splice. So there's no reason to design your splice to withstand a force larger than the yield strength of the smaller bar.
However, if you are splicing multiple rebars in the same position, going from a few large diameter bars to many smaller ones, an incremement to the splice length may be required.
In the figure below, for instance, assume this is a splice section, with the tension from the large red bars being transferred to the small blue ones. The arrows roughly represent the furthest distance that tension needs to travel from each bar.
The codes usually define a maximum distance between lapping rebars. The Brazilian code NBR-6118 and EC2 both put that limit at $4\phi$ or 50 mm. In this case, there's the question of which $\phi$ to use, and I honestly don't know. However, both codes do allow distances larger than this limit so long as the splice length is increased accordingly. So in cases such as the one pictured above, an increase to the splice length may be necessary to satisfy this requirement.
For reasons I can't quite fathom, though, the Brazilian code explicitly states that splices between different diameters must adopt the larger diameter, so that's what I'm stuck with.
    $\begingroup$ "... must adopt the larger diameter ...". It could be the code is considering construction conditions rather than purely structural design requirements; ie the effect of ribs (that increase the spacial diameter by about 20% for some bars), the effect of bonding of concrete when two or more bars is bundled and the fact that, statistically, there will be variations so they over-shoot to meet a minimum lap distance. The consensus may have just opted for the simplest and safest solution in this case. $\endgroup$
    – AsymLabs
    Commented Feb 23, 2018 at 16:03
-1
You can use steel reinforcement bar couplers to connect. Do not you think that this will be much easier? After all, you do not need to use welding equipment, only portable hydraulic pressing equipment. Simplicity and high assembly speed are advantages.
