I have used the Simulation Data Inspector in Simulink to log a dataset of two time varying signals. The only option I see concerning exporting is to .mat or to workspace, which basically produce the same type of output:
Simulink.sdi.Dataset
I have no way of opening this file or dataset, and I need to export it to Excel or to a simple text file with this format:
Time Var1 Var2
0 53 34
1 47 78
2 67 24
3 54 87
4 45 54
(tab separated values).
My goal is to use the logged data in LaTeX for a report, but as of now I am stuck with a 1x1 Dataset in the Workspace which I cannot use or read. I have checked the MATLAB manual online, but the export-function they refer to does not work with this simulink.sdi.dataset:
>> export(voutyngve2,'XLSfile','data.xls')
Undefined function 'export' for input arguments of type 'Simulink.sdi.Dataset'.
Can someone please give me a tip?
