What I want to know is a simple setup that can heat/cool a house using hdpe or pex pipes coiled deep underground (depth of approx 13 feet or 3.9 metres) through which air is circulated and thus, utilising the constant temperature of the soil that is maintained throughout the year - which is around 22°C or 71.6°F
I have a handpump in the lawn and noticed that the water from it feels really cool to touch in summers and really warm in the winters. (The max weather temperature here in summers reach around 38°C or 100.4°F and as for winters, the minimum reaches about -10°C or 14°F).
Also, the water table is quite high in my area (approx 1.5 metre or 4.9 feet) which seems to be helpful in further maintaining the constant underground temperature throughout the year.
Can the following simple set up do the job of maintaining the temperature of the house? -- a pipe (approx 8 inches/20 cm in diameter) is laid underground and air is circulated through it using exhaust fan into the house... would it be possible to maintain the temperature inside the house to some extent? Of course a single pipe would be going into the ground, but the pipe that comes out would then be insulated and then further branched out to different parts of the house.
Also, if the soil is modified - as in - the bottom most layer (where the pipes are laid) would be sandy soil, and the layer in the middle is a mix of silt & loam, and the topmost layer is clayey+loamy soil (4 feet each layer)... would that further help in this set up?
Also, what about the humdity/condensation? Would that cause any mold formation inside the pipes? How to prevent it?
Thanks a lot in advance for any insight/advice. I would very much prefer it to keep this setup as simple as possible.
