How to calculate the component of the centrifugal impulse in the y direction created through travelling along a semicircle from the x axis to the negative x axis, 1st and second quadrants? I am trying to compute the total impulse taking the changing direction of the acceleration into account as a mass m travels along a semicircle at constant velocity v. Need to find the total impulse in the y direction if the semicircle is in the first two quadrants about the origin. Need equation in terms of velocity, radius, mass, time to complete semicircle path.
To calculate the component of the centrifugal impulse in the y-direction, we'll break it down into smaller parts. Assuming a constant velocity v and mass m, we'll use the following steps:
  1. Find the centripetal acceleration (ac) in terms of v and radius (r): ac = v^2/r
  2. Since the mass is moving in a semicircle, the acceleration vector will change direction. We'll resolve the acceleration into its x and y components using trigonometry.
  3. Calculate the impulse (J) in the y-direction by integrating the y-component of the acceleration over time.
Here's the equation:
J_y = ∫[0,π] (m * v^2/r * sin(θ)) dθ
where θ is the angle from the x-axis to the position of the mass, ranging from 0 to π (covering the first two quadrants).
Simplifying and evaluating the integral, we get:
J_y = (2 * m * v^2)/r
This is the total impulse in the y-direction.
Is this correct?
    $\begingroup$ When I see the term "impulse," I assume it is sudden, such as would occur when a hammer hits something. Do you mean "force"? $\endgroup$ Commented Jul 30 at 1:24
  • $\begingroup$ If you mean force and against vertical gravity, it's centripetal force minus gravity, the classic loop the loop roller coaster calculation. It's an equation using the sin of the angle. $\endgroup$
    – Tiger Guy
    Commented Jul 30 at 5:19
  • $\begingroup$ @user1683793 impulse is force times time and does not have to be sudden $\endgroup$
    – Dale
    Commented Jul 30 at 18:59
You have calculated the integral right but the selected integral is totally wrong. You should calculate the time integral of the vertical force component, the variable shouldn't be the angle.
Of course you can make substitution so that the new variable is the position angle (dt=dθ/angular velocity), but there's no need to do it, because the result of the integration can be seen easily otherwise.
The mass particle moves in the beginning upwards. In the end of the calculation period it moves as fast downwards. The impulse = The change of the momentum = 2mv and that's downwards.
The integration of the vertical force component, of course, gives the same (checked; only divide your original integration result with the angular velocity, let it and the radius generate v to the denominator and eliminate the exponent of v).
  • $\begingroup$ That is the correct approach. Initial vertical momentum is +mv, final vertical momentum is -mv, so the the change is -2mv, which is also the impulse. $\endgroup$ Commented Jul 31 at 22:59
