-- Note: I've flagged this as unlikely to be a quality question. I've refined it and rephrased it as a Mathematics SE focused one instead. Find it here.
I am using a rotary encoder as a pivot point for a pendulum in a simple actuator mechanism. It is an incremental-only type meaning that it does not have a dedicated signal for absolute positioning, only two quadrature signals for relative motion.
(Optical Incremental Rotary Encoder. Picture from Amazon store page)
The encoder is used to detect angular deflection of the pendulum, where bottom-dead-centre will be calibrated to be 0 degrees, clockwise deflection will show as positive angles.
During the startup sequence, the actuator moves back and forth and swings the pendulum slightly (about 45 degrees) and then waits a while for the pendulum to come to a halt naturally. At this point I assume that the pendulum has come to rest at exactly vertically downwards.
Unfortunately, there is a very small amount of static friction in the encoder, which I believe to be due to the grease inside the two ball-bearings. When the pendulum is swinging, this "stiction" is not noticable when swinging rapidly or through a large angle. But when the pendulum is almost coming to a halt, the stiction visibly slows the pendulum and halts it before it has reached bottom-dead-centre. Often the final angle is perhaps 1 degree away from vertical, but this is enough to throw my calibration out.
My first though was to strip it down and swap the bearings out for grease-less ones, but it's an optical encoder and I must not allow any dust inside it as this would compromise the unit's accuracy. So I'm reluctant to disassemble it.
I did try adding a small weight to the end of the pendulum in the hope that it would have greater mechanical advantage over the stiction threshold, and it did improve matters slightly, but adding more weight would reduce the effectiveness of the system.
Is there anything that can be done without disassembling the encoder to reduce the effect of this stiction?
Further info:
The pendulum is an M5 threaded steel rod 210mm in length measured from the pivot to the end.
Removing the pendulum and turning the encoder shaft by hand, it is possible to feel this friction; it feels like a soft click after the shaft has been still for a moment. It is very reminiscent of the shear-force threshold in thick grease. Once the shaft gets moving, it's buttery smooth motion until it comes to rest again.
