CSR - Carbon composition resistors.
P1 :About tolerance resistors , what I have understood is that if a 220 Ω resistor has a color band of silver. Then , it’s tolerance = ± 22%. So , resistance of the CSR or the obstruction to the flow of electrons will be in the range of 242 or 198 Ω . Any one number value in this range. From the values 198 to 248 ohm. What does this mean ? Like resistance is obstruction to the flow of electrons. Formula is $R= $$\frac{V}{I}$. Now , the value of V and I should be such that resistance value is always between 198-242 ohm ? It cannot exceed or be lower than this range limit values.
Example in my textbook: P2: Also , in a CSR. Is it specified that from which direction the flow of electron is going to start. Left or right. Since online it says that resistors are blind to polarity.
I would like to confirm if for $1st$ part , my understanding is correct or not ?
For $2nd$ part , I am not getting what is the reason and the right answer.
