I was reading documents about energy importation and came across the following:
The import was of 5,915.87 MMtoe
I wonder if MMtoe = $10^6*10^6$ toe = $10^{12}$ toe.
First time coming across a unit expressed like that.
Sign up to join this communityI was reading documents about energy importation and came across the following:
TL;DR: the MM in MMtoe is probably related to the Latin Numeral M (for 1000). In that context MM means one thousand thousands (i.e. one million)
Although this is very confusing, the bottom line is that to (my understanding)
$$ 1 \text{ MMtoe} = 1 \text{ Mtoe} = 10^6\text{ toe}$$
Where:
To my (initial) understanding (I am willing to bet to a lot of other people accustomed to SI units):
So, I thought that the confusion arose because:
This is a brief explanation of the ton units.
the metric ton (which is relevant in the context of toe), is equal to 1000 kilograms, or approximately 2204 pounds. The metric ton is officially called tonne. The SI standard calls it tonne or Megagram (Mg), but the U.S. Government recommends calling it metric ton.
The British ton is the long ton( or displacement ton), which is 2240 pounds, and
the U.S. ton is the short ton which is 2000 pounds.
Both the long and short tons are actually defined in the same way. 1 ton is equal to 20 hundredweight. It is just the definition of the hundredweight that differs between countries.
Then after some prodding from PeteW comments, I looked around a bit, and found the following link. And it actually gets even more confusing.
It actually goes says that the $M$ is the Latin Numeral for 1000 (and not from Mega = 1000000). And that $MM$ stands for one thousand thousands (ie. one million).
That explains why, McF, and MMBtu are used in the manner they are used (and probably even MMtoe is the same because it seems to apply to energy units).
Despite all this (inconsistency, arbitrariness and -at the end of the day- just plain craziness), the bottom line is that MMtoe (irrespectively to the interpretation you use) is equal to 1 million tonnes of oil equivalent.
