When I read about stress analysis and specifically in the context of strain gauge, I often see the phrase resistance per unit strain
or voltage per unit strain
. I understand the electronics and how some of the equations are derived or come about. I have a basic understanding of what stress and strain are, but I don't get what per unit strain
is and why we're using it.
Take the simplest example - a strain gauge connected in series with a constant current source, where $ E $ is the voltage drop across a strain gauge, $ R_g $ is the resistance of the strain gauge, $ G_F $ the gage factor, and $ \epsilon $ the strain:
$$ E + \Delta E = I(R_g + \Delta R_g) $$ $$ \Delta E = I \Delta R_g = I R_g {\Delta R_g \over R_g} = I R_g G_F \epsilon$$
Everything makes sense until the equation is rearranged and call it the potential drop per unit of strain
$$ {\Delta E \over \epsilon} = I R_g G_F $$
One unit is a measure of unity. One unit of strain therefore is $ \epsilon = \Delta L / L_0 = unity = 1 $. That implies $ \Delta L = L_0 $, or the change in length equates its initial length. If the object is under tensile stress, $ \Delta L = L $ is a 100% elongation. So the term potential drop per unit of strain
would logically mean the voltage drop per each 100% elongation! Most strain being measured in the elastic region is well below a few percent. 100% elongation (or my take on per unit strain
) feels .... out of context here.
