An image of the actuator is below. I have a setup that was given to me where there is two configurations, namely 50mm travel and back, and 75mm travel and back to home position. There are two switches PC1 and PC2 which control the two programs via the CSRT switch.
Now I would like to extend the system to 4 program, example
- home, 100mm travel, home
- home, 75mm travel, home
- home, 50mm travel, home
- home, 25mm travel, home
To achieve this I plan to add 2 more switches, PC4, and PC8. After I add the switches my control box will look something like the following.
Below is an example wiring diagram.
Below is an example of the programming interface.
Below is an image of the electrical wiring interface.
Question: How do I wire the PC1, PC2, PC4 and PC8 so I can independently control 4 settings? Only 1 switched can be ON for a program. The other 3 switches have to be closed.
I am also open to hearing alternate solutions.
Here is the link for the vendor who sells the SCN5 actuator in question.
I personally would not do it like that for a small cylinder
. Can you please tell us how you would do it. $\endgroup$
