I am extending the Apache Tika parser for DWG files so that I can parse text out of DWG files.
Currently someone else has written some basic metadata parsing which is great. But the newer versions of DWG are not yet supported.
I would like to add that support, and extend what is possible to parse.
I read around online and the Spec for DWG file format is proprietary as far as I can tell, so does that mean there is no open specification document?
Any help anyone can contribute to help me parse DWG files would be appreciated!
  • $\begingroup$ The DXF format could be an alternate solution. $\endgroup$
    – DavidJ
    Commented Jan 9, 2021 at 0:30
    $\begingroup$ It is what proprietary means! Sort of defeats purpose if you publish a spec on it. $\endgroup$ Commented Jan 9, 2021 at 5:14
  • $\begingroup$ @nicholas-dipiazza Did you succeed in your task of creating a parser for DWG? I need the same. Can we collaborate? $\endgroup$
    – afrish
    Commented Mar 17, 2021 at 20:31
  • $\begingroup$ github.com/apache/tika/pull/395 here u go $\endgroup$ Commented Mar 17, 2021 at 22:41
While DWG files are a proprietary binary format by Autodesk, they gave some visibility at some point to the Open DesignAlliance and allowed them to make an open spec.
https://www.opendesign.com/files/guestdownloads/OpenDesign_Specification_for_.dwg_files.pdf
It's not perfect. You'll see situations where they weren't given enough information to prefect define something... such as:
We have occasionally seen other values here but their meaning (and importance) is unclear.
But it's better than nothing!
