Many bicycle cranks have permanently assembled spindles on one side, as shown in the picture. This is a steel spindle inside an aluminum crank arm. I am not sure how these are manufactured. But I sometimes build custom cranks and I want to duplicate this because it might be easier to press together a joint than to machine a spline on both sides for a joint that technically never needs to be disassembled.
Given the moderate forces involved, do you think this can be done just with a tight press fit? Can you suggest tolerances for the hole and spindle?
If a press fit wouldn't hold, what if I use a retaining compound like loctite 680?
