I have already set millimeters in document propertis, nevertheless the display units are meters
Why and how to fix?
  • $\begingroup$ Dumb question but need to ask- is your model set to the correct units? Check your drafting standard, restart, then check for any SW updates. Then try creating a new drawing file. $\endgroup$
    – jko
    Commented Sep 28, 2020 at 19:23
  • $\begingroup$ I don't have any model, I just created empty drawing $\endgroup$
    – Dims
    Commented Sep 28, 2020 at 19:26
  • $\begingroup$ my parts come out in meters when I'm not correctly connected to my VPN, meaning SW falls back on its internal default template - check your template path, and check the templates are correct and in that location $\endgroup$ Commented Sep 29, 2020 at 21:29
There are many possible culprits. One of them is the following.
Check in the lower right corner of your Solidworks window. you should see
if you click on it, you should see the following menu.
You might have pressed it accidentally.
