-1
I am a student and is making power project using Push-Pull transformer. I used the Reference design: TI Designs: TIDA-01352. I stuck to find 2 replaceable Push-Pull transformers as in suggesting transformers(750340744 & 750343547 of Wurth Electronik).
These are two datasheets of the transformer I want to replace.
750343547: https://www.we-online.de/katalog/datasheet/750343547.pdf
750340744: https://www.we-online.com/catalog/datasheet/750340744.pdf
I tried to find on Mouser, Digikey, etc. Could you suggest me to find there transformers with above similar specifications?
P/S: I sent to Wruk Electronik to ask, but they want more information about name project, company name, my job, the price I want, etc. It made me confused. That is reseason why I want to replace them with similar specifications
  • $\begingroup$ those two sheets describe radically different parts. what parameters are important? $\endgroup$
    – Jasen
    Dec 31 '19 at 22:01
  • $\begingroup$ The turn ratio is the importance. $\endgroup$ Jan 2 '20 at 7:18
On digikey you'll find that sort of thing under "pulse transformers", on element14 under "coupled inductors" on mouser under "coupled inductors" again.
  • $\begingroup$ Following your suggestion, I found 2 types. But I still wonder about the Turns ratio of the push-pull transformer. $\endgroup$ Jan 2 '20 at 13:37
For the current transformer(750340744), I found a replaceable one: 53100C with turn ratio: 1:100; primary current rating 10A.
For the push-pull transformer(750340744), I found a replaceable one: PH9385.015NL. But I still wonder about turns ratio. The datasheet said that: Turns Ratio (1:4):(8:5) = 1:5. In my design, pin 2 ties to pin 3 and pin 7 ties to pin 6. And I want Turns Ratio (1-2):(8-7) = 1:5 ; (1-2):(6-5)=1:5; (1-2):(3-4) = 1:1. So, whether this transformer is what I need?
