"Work (as in Thermodynamics) is said to be done by a system if sole effect on the surroundings could be the raising of a weight." So, how is non mechanical work like : Chemical work, Magnetization work or even electric current flow work be reduced to the same?
$\begingroup$ Do you mean a chemical reaction? ie fizz fizz bubble bubble ? What definition do you have for electric current? And, best yet, do permanent magnets loose power over time ? $\endgroup$– Solar MikeMar 30, 2019 at 15:13
1 Answer
Other work is also a flow of energy between system and surroundings (across a boundary). Heat is flow of energy too. Consider these three sayings as analogous:
Mechanical work is said to be done BY a system if the sole effect on the surroundings could be the raising of a weight (in the surroundings).
Heat flow is said to be EXOTHERMIC if the sole effect on the surroundings could be an increase in the temperature of the surroundings.
Other work is said to be done BY a system if the sole effect on the surroundings could be either the raising of a weight (in the surroundings) or an increase in the temperature of the surroundings.
$\begingroup$ thank you so much for your reply. now it is clear to me. $\endgroup$– user19926Apr 20, 2019 at 18:18
