I need to buy a level switch for a quench tower water drainage system. I intend to use its output directly to open a solenoid valve to drain the tank when the switch detects water and close it afterward when the water recedes. I have identified make and model of a level switch I think is good. But the manufacturer provides multiple types of electrical outputs. It would be great if someone could advise on which of the following type is best for a simple level switch - solenoid valve circuit.
  1. Relay
  2. NAMUR
  3. Transistor
  4. 2-wire
P.S: I am a newbie regarding electrical stuff. I'll consult a friend who will help me to design the circuit, but I just need to place the order for the level switch.
    $\begingroup$ Welcome to Engineering.SE . Could you add a link to the family of the sensors that you like? Could you tell us what you're going to connect the sensor to? $\endgroup$ Commented Feb 20, 2019 at 5:43
  • $\begingroup$ Can you share the make and model of the Level Switch? Can you share the specification of the Solenoid Valve? $\endgroup$ Commented Feb 21, 2019 at 1:55
  • $\begingroup$ What are the current and voltage requirements to "directly to open a solenoid valve"? If these matched those of the "relay" option you might be able to not use a relay itself, but chances are pretty high that you will just have to use a relay or transistor in the middle and go with the appropriate output option. $\endgroup$
    – Abel
    Commented Apr 5, 2021 at 2:06
How about using a latching solenoid valve like the following?
1/2" Magnetically Latching Solenoid Valve DC 6 V
Use a h-bridge driver to switch on and off the valve. Below is one that I have used most recently.
DRV8833 Dual Motor Driver Carrier \ enter image description here
HTH
    $\begingroup$ The only reason to add the additional complexity would be to conserve energy but this does not seem to be an issue for the OP. $\endgroup$
    – Transistor
    Commented Aug 13, 2019 at 20:53
