I am currently looking ways to control or siwtch a max 220v 35A load. Simple magnetic relay rated for such load would work, but i am exploring the other alternatives too.
here i stumbled into triacs, in which solid state relays are made of. I stumbled into this ic
https://www.st.com/resource/en/datasheet/t16t.pdf
and i could not get the grasp on how a small triac such as this one.
is able to switch a high load of 220v 16amps
Thank you!
