in most of car cabin filters (for example MANN filter) I see that I need to place it according the "Air flow" label? But why I need to do that? What will be wrong if I will put it in opposite side of "Air flow" label?
Usually because the strengthening in the filter is optimised for one direction and the layers may also be optimised so the oncoming air is met with a coarse layer first, followed by successively finer layers.
  • $\begingroup$ Thanks it makes sense. It is much more clear for me now. $\endgroup$ Commented Apr 4, 2018 at 15:09
  • $\begingroup$ filters of that type are called "through" filters; they rely on the graded density increase to maintain flow while capturing the particulates and also to safely entrain as much material as possible before the filter becomes unserviceably plugged with stuff. $\endgroup$ Commented Apr 4, 2018 at 18:17
  • $\begingroup$ Are there another types of cabin filters? $\endgroup$ Commented Apr 5, 2018 at 14:46
  • $\begingroup$ Simple, pollen then HEPA $\endgroup$
    Commented Apr 5, 2018 at 14:50
  • $\begingroup$ Thanks and what type of filter described in answer? $\endgroup$ Commented Apr 6, 2018 at 7:32
