[was told to post here, from physics stackexchange]
Says it in the title - I've done a bunch of stuff so far, but my work seems to be wrong.
I'm trying to build an RC car (pretty small, about 25 cm in length) with a manual transmission (3-speed), so I was running some math to see what motor I should buy, and what gear ratios I should use.
I'm using a brushed DC motor, and some pages I've seen have around $12000$ peak RPM and $714$ gcm peak torque.
In an attempt to try out some gear ratios, I tried to model the behavior of the car as follows:
Since the torque-rpm curve of the motor is linear, We can formulate them as:
$$ T = T_{max}(1-\frac{\omega}{\omega_{max}}) $$
(where $T$ is the torque, and $r$ is the wheel radius below)
Now, the acceleration of the RC car would be:
$$\frac{dv}{dt} = a = \frac{F}{m} = \frac{T}{mr} = \frac{T_{max}}{rm}(1-\frac{\omega}{\omega_{max}}) = \frac{T_{max}}{mr}(1-\frac{v}{r\omega_{max}})$$
Now, I take $T_{max} = T_{motor}\cdot G$ and $\omega_{max} = \frac{w_{motor}}{G}$, for some overall gear ratio $G$.
when graphed together, for various gear ratios, things don't seem right - the graph shows that the car takes (almost) the same amount of time to reach a maximum or target speed, regardless of if it had some initial speed.
Take a look at this plot, where the red goes from 1st gear, 2nd gear, and then to 3rd gear, but the blue is simply just the 3rd gear from the beginning. (here, taking $T_{motor} = 0.07 Nm \cdot Gear, \omega_{motor} = 12000 \cdot \frac{2\pi}{Gear\cdot60}$)
Red: 1st gear (G=100) shifted to 2nd (G=25) at t=4s; blue: G=25 from the beginning to end.
[Red: 1st gear (G=100) shifted to 2nd (G=25) at t=4s; blue: G=25 from the beginning to end.]
What am I doing wrong here? shouldn't the red curve accelerate much faster? Are the gears shifting at the wrong time? Am I using the wrong gear ratios (I cannot find the right ones)? Is the equation and model inaccurate?
Your plot seems to be missing second gear.
In general, top gear is chosen so that the peak power output of the motor vs. RPM curve matches the drag force at that vehicle speed. At that condition, if you geared the transmission a bit lower, the car would run slower, and if you geared it a bit taller, the car would run a bit slower as well.
The first gear curve is correct, but you are shifting out of first too late. You should shift to second about one second after starting off. Quick shifts like this will get you to top speed sooner by increasing your acceleration rate at slower speeds.
  • $\begingroup$ so mathematically, when am I supposed to shift? I just want to get a generalized answer. $\endgroup$ Aug 26 at 0:07
  • $\begingroup$ You shift when the power curve begins to slope noticeably downward. $\endgroup$ Aug 26 at 17:22
  • $\begingroup$ You shift when the power for gear 2 matches the power for gear 1 at the same speed. Max acc is a power game, despite what the amateurs will tell you. To wrap your head around that suppose you had a perfect CVT, would you hold max torque or max power for max acc? $\endgroup$ Sep 25 at 7:36
